Symbols won't budge.
    Okay, the newbie to Revit MEP 2011 has another profound question...
    I've made beautiful equipment that works when I put it in a project - ducting and piping connects and stays connected.
    I've made electrical symbols for this equipment and would like to put it in the equipment families like tags so that when I place the equipment, all I have to do is grab the symbol and place it relative to the equipment to make it 'look pretty'.
    Can this be done?
    How?
    Should I just place all the symbols after placing the equipment which seems rather tedious...:crazy:
    Ciao for now.
    Say something interesting....
    I think you want to use Tags for this. If you put the Symbol in the Family you can theoretically move it around if you make the placement parametric (Dimension to a refplane and make the dimensions parameters). But this has a lot of disadvantages, so I wouldn't recommend this.
    You can however place symbols in Tags and use these to Tag in your project. If you use the Tag All option you can Tag all instances. You can also select Place Component and then check the " Tag on Placement" option in the Options Bar which creates an automatic tag on placement.
      Thank you! I'll give it a try...
      • Tagging Equipment in a Linked Model
        I'm working on my first electrical project with three (3) separate models for MEP. I'm stumped trying to figure out how to tag mechanical and plumbing...
        October 3, 2015, 04:46 PM
      • How do you handle thermostats?
        I've been using Revit for 5 years at this point and I'm still trying to figure out the best way to handle thermostats with the set of tools we have available....
        August 12, 2015, 10:32 PM
      • symbols for tagging...
        hi
        i discovered today that it's possible to add a symbol OR (may be and, don't know) a tag
        in found this option in loaded tags...
        so...
        April 8, 2020, 03:08 PM
      • Radiator Tags
        I have put some radiators on the ground floor of my project, and I have tagged them however the tag is empty (jsut a question mark) How do I edit this...
        April 24, 2014, 02:25 PM
      • Line in Tag Visibility
        Is it possible to control the visibility of lines in a tag by the tagged elements shared parameters? I'm wondering if it is possible to have a tag that...
        January 29, 2019, 08:23 PM
