led light
    led light
    Hey, I am working on the led line strip, which follow particular shape. The light have to come from behind the letters ZEN and it has to be pink.
    My problem is: i can't find a light family whish will allow me to bend around the curvy shapes. Another question is how do i give a color to the light in revit?
    Is it is any way i can draw the path for the light and than specify the color and intensity?
    Many thanks.
    In-place family with self illuminating mat?
      Where I can find the illuminating material? Or how can I set it up?
        Googled a little for you:
        Revit TotD – 7.9.09: Glowing Sign, Self-Illumination Based Materials
          Thanks a lot for your help
            Hey, now I have a problem with my light is not showing in render. Is any one know what is going on?
              Here is my troubled file
                Any chance you're using Autodesk online rendering?
                  Do you mean Autodesk360 online rendering? just sine up to it, my e-mail [email protected]
                    The reason cerb0z asks about 360, is due to the fact that 360 won't render self-illuminating materials....
                    Had a quick look at your family, and it looks like you're on the right track... The problem may be that your family is using "Default Light Source" for the self-illuminating material name, a name which may already exist in the project you load it in to, why the default material settings will be used in the project, and not the settings you altered in the family. The fix would be to alter the "Default Light Source" material in the project, and not in the family... OR to rename the material to something not already in use in the project.
