Parametric Cupboards!
    Hi all, first proper post so here goes!
    I am creating some joinery for an apartment, until now have been creating from scratch etc., quite time consuming. So I decided to make a family- however the problem I am running into is how to get the carcass to appear/create itself when the width goes over a certain amount, say 500.
    Any ideas? I hope the attached image helps.
    Thanks!
    www.moleculeweb.com
    Not sure what a carcass is, but assuming it's a piece of geometry:
    Create a new yes/no parameter "Show Carcass" and enter something like this in the formula field: if(width > 500)
    Now, just tie the visibility of the carcass geometry to the new parameter, and you should be good to go.
    And welcome to the forum BTW. :beer:
      Hmm I am half way there, but it is telling me that "> operator not expected"
      Is there anything more that I need to do?
      Thanks for the welcome!
      www.moleculeweb.com
        I think, that you only need to put "width>500" in the formular.. Since its just yes/no it will figure it out it self..
          Sorry, my bad. The formula should not use the if statement, but only:
          Width > 500
            Great! Thanks muchly.
            www.moleculeweb.com
              Width > 500
              I am trying to do this formula, but it's not working. I have a yes/no parameter set up and the formula I am using is =Length > 93" but Revit gives me an "invalid formula" error. What am I missing??
              Thanks!
                can you post a screenshot?
                in the family you don't need the = since it is implicit in the formula field. The other thing to check is the parameter Length. Is it spelled correctly, capitalized correctly etc?
                chad
                  Sorry, the way I wrote that was kind of confusing. I did not add an extra =. Additionally, the parameter is spelled and capitalized correctly. The REAL formula I want to use is:
                  Side Door Swing In = if(and(Side Door, not(Length < 93")), "True", "False")
                  but I get an error with that, so I thought breaking it down in to multiple parameters may solve that? I'd rather focus on making this long one work than spend time on the short formula. The error I get is "inconsistent units," so I tried dividing and multiplying the Length by 1, as seen in other posts, but that doesn't change anything. What I'm really trying to say is if the "Side Door" extrusion is set to visible, and the "Length" of the stall is greater than or equal to 7'-9", then the door will "Swing In." Maybe I'm going about this the wrong way?
