Door Tag
    Door Tag
    Hi All,
    Can someone please tell me if it is possible to create a door tag that will read the Room Name or Room Number that it is placed in the project?
    I am guessing it is a shared perameter simply placed into to door tag and the project or can you use the otb room tag?
    Andrew Harp
    BIM Manager GHD
    You could add a shared parameter, but you would have to manually type in the Room name/number, there isnt any way to get it too read it/link it to the room name/number
    Alex Page
    RevitWorks Ltd
      As Alex mentioned OOTB there is no automatic way of doing this.
      Through the API you can and I'm pretty sure there are existing API tools out there that does just what you are after.
      Phillip Miller
      Kiwi Codes Solutions Ltd
      Makers of "Family Browser" and "Project Browser" for Revit.
        Thanks guys,
        It would be a nice feature to be able to associate a door to a room and auto fill the tag parameters. I think ADT works this way by associating with the room space, could be wrong though.
        Any ideas on who has a plug in for this feature?
        Andrew Harp
        BIM Manager GHD
          does this help at all??
          Fear and Loathing In a CAD vs. BIM World: Door Tags by Room Number: "Want 'em?" Got 'em"
          or one API solution
          reviTTools.com
          Cheers
          Phillip
          Phillip Miller
