Title Block Information
    Hi All,
    I need to place a label in my title block. This label will need to be called "Plotted By". I am assuming that this label should be resading the username registered to the revit session. Is this correct? How do I go about getting this label to read correctly?
    Andrew Harp
    BIM Manager GHD
    Yep, It's Monday!!
    Just ignor this Thread. I didn't see the actual plotted by label that existed already!
    All sorted now.
    Andrew Harp
    BIM Manager GHD
      Hmmm... Don't recall having a "plotted by" parameter? Are you sure that it's a system parameter? And not just a old custom/shared parameter?
