tag for system family
    hi,
    for the wall as a system family it has no tags, how can i add a tag to it with multi data like fire rated, height and material
    Sure there is! If there's not one loaded with your region's template, you'll be able to easily load one from the supplied metric/imperial library - there's normally two or three premade ones which you can always and add the fields as you required.
      thank you ,it goes with me
