Shared Parameter for a Symbol Tag
    Hi Guys
    I have made a symbol family and added a couple of tags. I wanted them to be shared so I could schedule them. However, I cant.
    Any way around this?
    What your tagging has to have the shared parameters too...A tag by itself won't populate a schedule.
      Hmmm maybe a badly worded subject and OP.
      I have a symbol family. The family consists of lines and labels. I want the labels to be shared parameters so when I add the symbols to my drawings I can schedule them to keep track of them.
      Apologies for the confusion.
        What type of schedule are you trying to do? I think the only type that may work is a note block
          Its a revision block that I have made. I want to schedule it so I can check the drawing revisions and dates and update on 'mass' I.e not having to open each sheet, I can go down the schedule and update from there?
            What is your symbol trying to convey? Maybe your going the wrong direction...
            A symbol or tag get's its information from an actual object (doors, furniture, windows, etc...) this is what gets scheduled, not the tag itself. A tag is just a 2D element placed in a view to call out an object.
              You can create a Sheet List that has the information from the Revision Block...and modify everything there instead of going sheet to sheet...
                Ive not used the Revision function in RS at all after I was warned away from it many years ago, seems like I need to now
                  If your company uses a combination of letters and numbers for revisions, then yes, you will have issues with the Revit Revision block. It can do either numbers or letters but not both.
