sheets in families
    sheets in families
    hello
    i created a "wunderbar" parametric family of a tank and i'd like to know if it's possible to create sheets in family?
    of course i can create sheet of the speciality equipment in a project but i should need to recreate the sheet on others projects whereas, if sheet is in the family everything is in the box!!
    Phil
    Freelance WWTP/HVAC Designer
    Revit 2019
    Hi Phill, AFAIK you can't create sheets in families see attached image
    E.A Poe
      hi Andres,
      I unfortunaletly expected that answer... :/
      Phil
      Revit 2019
