Array to 2nd or Last?
    I have been making families for some years. When it comes to using Array in family, I always remember to use array to "last" and it had worked out just fine for me. I admit that when I first learned how to build family by going thru the on-line video, I was told only using array to "last" and never use to "2nd".
    Lately, I have talked to some Revit peer regards to Array, and I notice that they use the other option "2nd" for the array, and they told me that how they have been doing it.
    So, that got my curiosity started and I wanted to post this question to all the Revit users to see how you are dealing with array.
    Thanks and look forward to your comments!
    P
    Philip Chan
    Practice Technology Manager | HKS
    http://phil-osophyinbim.blogspot.com/
    I use array (to last) when I want something to stretch/expand/fill/populate something across a given distance.
    I use array (to second) when I want something to repeat/occur/happen/space something across an incremental distance.
      Exactly like snowy...
      To Last when you have a fixed endpoint and the amount of arrays varies.
      To Second when you have a variation in endpoint depending on the amount of arrays / when you have a fixed distance between two elements of the array
        +1 with me.
        And I always use the constrain option.
        Julien
        P. DAC
          Interesing point on how you use both options.
          I did remember to use array to 2nd in a few cases but it seems like I have better control when I use Array to Last.
          Will probably investigate a bit further when I have time later. Thanks for the comments.
          P
          Philip Chan
