Yes/No visibility parameter formula problem?
    Hi guys and gals,
    I have a problem where I am trying to have a <yes/no> parameter turn on if <Panel Number> is less than 2 and turn off if it is lesser than 1.
    I can achieve one or the other with:
    <yes/no> = <Panel Number> < 2
    but how do i make it so in addition to the above it turns off if <Panel Number> < 1
    any help is greatly appreciated.
    Milos
    Not sure if this is exactly what you are after, but Alfredo gave a very good explanation of dealing with the visibility of nested components in http://www.revitforum.org/architectu...es-needed.html
    Ian Kidston
    http://allextensions.com.au
      Thanks Ian, but not quite what I am looking for.
      I want to apply visibility (on/off) to one object in such a way that it is off until "Panel Number parameter" is <2, then it is turned on if "Panel Number parameter" is 1 and turn off again if "Panel Number parameter" is set to 0 or less.
      Great read none the less, I may need to revise my Door family based on what I've read.
        If "Panel Number parameter" is an integer then wouldn't your visibility parameter simply apply if "Panel Number parameter = 1"?
        Michael
        Canberra, Australia
          OK, the best place to understand formulas which can be used in revit is Klaus's thread http://www.revitforum.org/tutorials-...day-usage.html Pretty sure what you are after is in there.
          Ian Kidston
            HA HA
            it was the equal sign (=)
            I was trying different IF statements with x<2 and x>0 but it was the frikin "="
            Thank you both!
            That link is amazing, thanks for that.
              Originally posted by milos View Post
              HA HA
              Thank you both!
              Yes, That particular thread we go down in Revit history. A mere 387,000 views thus far!!!!
              Ian Kidston
