wall system --> insolution --> by category --> create subcategory to wall system -->
    I've a idea to switch hatch patterns, so that for every scale is a good pattern, but I dont know of it works.
    I create a wall system --> edit type, --> edit construction
    Select the material: by Category
    Anyone a idea were I can find this category? not by object styles..
    of how can I create a subcategory by system families?
    then create view template (right button on your plan in the projectbrowser)
    Edit overides model
    How can I override an object style?
    I think were anyone have a solution for my problems,
    (Anyone a idea were I can find this category? not by object styles..
    of how can I create a subcategory by system families?How can I override an object style?)
    then I can make a different hatch in different views in the same system family
    so by a view 1:100 i have a hatch insolution1/100.pat
    by a view 1:50 i have hatch insolution1/50.pat for the same wall
    anyone understand it?
    Not worth the hassle IMHO. Wen't down that same road when I first started using Revit... Didn't take long before I came to accept that a generic hatch pattern was needed for insulation (a "dot" like pattern)
    And FWIW, the workflow you are suggestion is not going to work.
