Title Blocks Create 2 stamps
    sorry but my english is not so good.
    I've a problem to create 2 stamps into my Title Blocks
    I would be create 2 different stamps in 2 different familys (with Generic Annotation),
    and i would load this stamps into bij title blocks family, so that i can see one of them with the visibility parameter.
    Now can I create label's in the familys but the is a limit numbers of parameters
    I can create self a parameter Projectname but I would be custom the Project Name, Project Number, Project Client etc. from revit self!
    So can anyone tell me what I must do?
    Don't worry dude, welcome to the forum.
    It sounds like you're having troubles with titleblocks - before jumping into starting a new post perhaps try a search first?
    There's a thread just under yours...
    - that should (hopefully) pick up your questions about custom parameters in a titleblock, adding gen. annotation families, and such. :thumbsup:
      Generic Annotation create label project parameter
      Thank you,
      I've read that thread but it's not a answer of my question.
      I've create a titleblock family with family types for paperformat A1, A2, A3, A4 ...
      Now would I create on A4 and A3 format title blocks a small stamp and on the bigger formats an bigg stamp.
      First I create in te title block an detail group with labels (project name, project client, .. ) and logo's,
      but you can't create an visibility parameter for detail groups.
      So I would create a generic annotation family and load it in my title block family and load this in my project.
      I can create labels in the generic annotation but not the Project Information Parameters with Revit self have create.
      I can only create a family parameter and I can't select an shared parameter.
      Hopely can anyone help me?
        Make both the items in your detail group and your main titleblock a "Titleblock" family. You should be able to load a TB into an other TB and link the parameters.
        TB should also allow you to do shared parameters.
          You can't load a title block family in a other title block family
            Have you tried changing the stamp to a "symbol" family?
