Family Parameters
    Family Parameters
    I have created tack board family. The family does not have a manufacturer, model number, etc parameter in the family file. When I load it into the project file, those types of identity parameters are there. I would like to add that info to the family file so that it is part of family no matter what project I use it in.
    When I tried to add the parameter to the family file it said it already existed. How do I do this.
    See attached.
    Cliff B. Collins
    Registered Architect
    Autodesk Expert Elite
      Not sure I follow your reply. I have tried adding a parameter to my family. Specifically "Model" and "Manufacturer" but when I click "OK" to complete adding the parameter it says I already have one by that name. It is not listed in the family file so I cant add date to it, but when the family is loaded into a project file then there are several Identity Data parameters listed.
        Are you sure Identity is expanded in the family types dialog and you not seeing it because it is collapsed. I've noticed the Identity category gets collapsed a lot since 2011
          while in the project...select the family, in properties "edit type".....there you can add the info
          (if I'm understanding this correctly)
          "Two possibilities exist. Either we are alone in the universe, or we are not.
          Both are equally terrifying."
          - Arthur C Clarke
            Sure enough the identity was collapsed. Looking at it gave me no clue. Thanks for the tip.
