Parametric family
    Parametric family
    Hello to all,
    Can anyone help me to figure it out why when change the type name of the road from 4 m into one with type name 4m to 6m and from 4m to 6m to 4 m does not work properly. The road should move exactly like the reference planes. The only situation when that road work just like I want is when I change the type name from 4m into one of 6 m. In the attachment I inserted the Revit 2017 file.
    Thank you in advance for your support.
    Quite a few things to go through - but you want to:
    1. lock the centre of the sweep's arc
    2. lock the centre of the corner-bank element (?) arc
    3. reconsider which ref.plane sets up your origin (I would pick the arc centre)
    4. remove the 6000 dim to right (above the <Lengthe_2> constraint
    5. define & constrain a "helper" parameter for inner-radius
    6. accept that you can not have differing width's for a sweep (You need to use a swept-blend for that)
    EDIT#1
    EDIT#2
    Generally speaking though, it's your cambered profile, and desire to shape/flare between two widths that are setting the challenge - not the family rigging. Namely, rather than sketched-profiles, you would be advised to define a profile family so that you can articulate the (road) width and camber - and help counter the issues you'll have accommodating the blend.
    NB: you might want to look at using an Adaptive Component to do this.
    Additional thought: unless these are going to repeating precast modules, ala Scaletrix, then you're probably best off making the lengthes (sic) instance based.
      Hi, ok, thank you for your feedback, but my desire is to able tho change the with of the road not the length. The second attachment - exercitiu is made with swept blend but when I change one with from 4 to 6m and th other one stays at 6m or in the other case to 4 m the problem what I encounter is on radius, which is not tangent to the the center. Can you help me with that issue, maybe you can be able to put a revit file with that situation?
        The "issue" with the radius is (please forgive my explaining the obvious) that a radius is, by definition, a constant of an arc - so the challenge presented here is that the arc's centre point will "shift" the centre point, and angular size, to accommodate the variable widths of road - even with a 90degree turn.
        You could potentially change the circular-arc to an elliptical-arc, but since this is a road, and roads have their own rules for turns, I don't think applying base geometric rules is really going to return a "correct" result.
          Thank you snowyweston.
