Rotate drafting pattern within detail item 2017
    I have created a plywood detail item that has a drafting pattern inside of it that consists of diagonal lines. when the plywood detail item is horizontal or vertical those diagonal lines read correctly. anytime i place the plywood detail item at an angle the diagonal drafting pattern doesnt rotate with the detail item. wondering if there is a way to correct this? meaning if i rotate the detail item 30 degree the drafting pattern within will also rotate.
    i am going to attach this detail item for your review
    You'll need to use a model pattern to get the lines to rotate - tab select the pattern and use the rotate or align tool. Model patterns will also scale according to view scale.
    Drafting patterns are always displayed at the same size and rotation, regardless of element position or view scale.
      Despite years of people asking Autodesk to make this possible they steadfastly refuse to budge
