Formula using degrees
    I've attached an image of what I'm trying to achieve but I just can't find that correct syntax. I am trying to say the following:
    If Astragal equals True than be 0 degrees else be the value of Plan Swing Angle.
    Any help would be greatly appreciated. Thanks!:thumbsup:
    if(Astragal, 0, Plan Swing Angle)
    You don't need to add the = true bit
      Thank you Robin! Out of curiosity, if I wanted to say Astragal = False, would the statement be if(Not Astragal, 0, Plan Swing Angle)?
        if(not(Astragal), 0, Plan Swing Angle)
        For more formula's check out this thread, helped me A LOT when I started with revit and still does:
        Revit Formulas for "everyday" usage
          I've tried to condense all the Formulas commonly used on my own OneNote Page. See attached...
            same! I have it on my bookmark toolbar and reference it all the time.
            chad
