Change glass panel in curtain wall
    hi,
    im new here and i have questions, how to change glass panel in curtain wall, e.g., i create custom cutrain wall and window but a need to insert bim glass panel from other manufacturer and i stuck there, cant change default glass panel with bim glass
    Originally posted by neznani View Post
    hi,
    if the manufacturer's "bim glass" is a curtain panel .rfa file just load it in your project. Tab select the curtain panel that you'd like to replace and in the Type pane in the Properties palette select the new curtain panel type and your panel type will change.
      Or change them all at once for a type of curtain wall in the Type Properties
