Nested Family Moving When Changing <Type> Parameter
    I'm stumped. I'm messing with my window family and trying to swap out what would normally be exterior trim for interior casing. All of that is controlled with the Family Type parameter and swapping things around works, except for the fact that when changing the exterior piece to casing it shifts by the window height, as if the family origin is different. If I swap the casing for the exterior trim it works fine. Any ideas on what is going on?
    https://www.screencast.com/t/HS4RssIE
    chad
    What version of Revit and what Service Pack or Web Update?
      17.0.1146.0
      20170816_0615(x64
      2017.2.2
      FWIW - I'm seeing the same behavior in 2018.2.0.51
      chad
