Sometimes Two or More family Do not Place in Body Align
    I have faced a critical problem.Sometimes two or more family do not place in their body/frame align.
    But they all family are place in individually very fine.
    Please See the attached photo.
    What Can I do now? Plz help me....
    Hi Sajibb, Those are nested families?, I guess that You need to verify if the thickness of the wall is sufficient, Check the constrains and finally if you can upload the family here to try it can help us to understand the problem, regards
    E.A Poe
      Nope! it is not nested family.
      Here I upload this family. Please Check
        Hi Sajibb, I'm curious, Are you placing multiple times this family just changing its dimensions?; I just noticed that the family working more or less the same way that in your images when I change the wall thickness see image, is this the problem you are facing off?, can you post a section of your project pleas?, regards
        E.A Poe
