family who cut two panels at the same time
    Hello,
    is there a possibility to make a family who cuts in two panels at the same time ?
    I need a family door/window who you can drag wherever you want in a curtain wall without messing with the grids.
    With a wall opening you can cut in 2 panels and drag where you want it, but can you make this with a family asswell ?
    thx for the advice
    Sure...if you don't have grids. But curtain wall doors are made to replace panels and panels are constrained by grids.
    Else, use a wall instead of a curtain wall.
      Thx for the answer
      Problem is that i need to use the curtain walls with grids, i need to make a plan for sip panels. I have to see the seperations from the panels in a plan view and elevation view. Unfortenaly that's not possible with a normal wall. yes you can make a surfacepattern with the correct dimensions so yuo can see that in the elevation view, but you cant see that pattern in a plan view.(cutting the wall) I also need a quantity count of the sip panels used.
      I just find it strange you can cut 2 panels with a wall opening, can't understand why you can't do that with a opening nested in a family for example
        You can still make a curtain wall door in the middle of a larger panel, or between two panels - you just have to do some careful segments and merging. It will get more complicated if you are using custom panels.
        Julie Kidder
        Architect + BIM Director
          Originally posted by mrkong View Post
          Thx for the answer
          why not just edit your curtain wall profile and put a hole where ever you want? What is a SIP panel? If it's a door like others have assumed just build a wall in the hole and add a door to it
            Structural insulated panel.
              Every time I've interacted with a curtain wall with an edited profile there are panel fragments that produce errors - do you just ignore those, or have a solution for them?
              Julie Kidder
                I kill them with RAID! seriously I just turn them into empty panels so they don't schedule then ignore them. This is another in what is a long list of Revit curtain wall idiosyncrasies. I don't let it get me down...
                  thanks for that but now I'm curious...what is a "structural" insulated panel and how is it different than any other insulated panel?
                  edit: and if I had to put a, say concrete panel into the hole I would just create another curtain wall type with no mullions, create one in the hole and have it's curtain panel be of a makeup to mimic a concrete panel...that work?
                    Rigid insulation with (usually) steel or fc sheet laminated either side
