Shelving Array
    Shelving Array
    I know I"ve dealt with this before, but I thought I'd try a different tack this time.
    I'm placing Shelving in a Cabinet family.
    What I'd like to do is to use an Array with the "Last" option (as opposed to "2nd")
    The problem with that is the first and last elements in the array end up inside the box of the cabinet and should be hidden,
    I only want to see the shelves in the middle.
    But since the Array Groups the shelves, I can't use an Instance Visibility. It's all or nothing.
    Any ideas?
    Other than the usual stupid "One case for a single shelf, another for two and an Array for 3 or more"?
    Dave Plumb
    BWBR Architects; St Paul, MN
    no.. other than I don't use the "another for two" workflow -- one for single and an array for everything else (unless the ends need to be different.
    Greg McDowell Jr
    about.me/GMcDowellJr
      [ATTACH=CONFIG]29758[/ATTACH]
      Any ideas?
      Why do you not want a parameter defining the offset from top & bottom?
      chad
        Chad, I guess that's what I'm going to have to do.
        I was just hoping I could let the Array do all the work for me. Match is hard!
        And, if I could hide the ends, I wouldn't have to set up the "just one" foolishness.
        You're right Greg, I don't need a separate set to "just two." I was thinking of a window with mullions where you have two panes, but one mullion.
        Mostly, I guess I'm just complaining (again) about not being able to use 0 or 1 as an Array count. That would make things SO much simpler.
        Dave Plumb
          If you don't need to schedule the shelves themselves, just the number count, you can use a 'next' array. Using an array of 1 will just require you to specify that the second array element is spaced at 0 so they overlap.
          Want to note that I generally do not use this method, but it is possible to avoid the 'use a single element for 1, use an array for more than 1' method.
            Off the cuff and Not tested but the math in concept believe works
            Total height / (shelf count+1) = spacing
            Begin offset = spacing
            End offset = spacing
            Constrain between bottom and first ref plane = begin offset
            Constrain between top and last ref plane = end offset
            Shelf constrained to first ref plane and arrayed using count to last ref plane
              Kinda like what chad was saying
              thats what I'd be doing :wine:
                It's done.
                But - SO many parameters!
                • Two for Visibiity
                • One for Spacing
                • One for User input
                • One to adjust the array so it can't be 0 or 1
                And double that for the vertical dividers
                That's why I was hoping I could just use a "Last" Array - and let the Count be 0 or 1.
                If I could have both of those, the whole thing could be done with one parameter. <sigh>
                Dave Plumb
                  I would use a few extra parameters and make the slats individual so they don't cross.
                  You've already made it this far, might as well make it look sharp in the views.
                    Using adaptive components it is possible to create arrays with 1 item.
                    They allow you to repeat not just a single element but a pattern of elements along points on a line.
                    So if you place Shelf A and Shelf B then repeat that pattern you can say 'If number of shelves = 1 then array length = 2 but visibility of Shelf B is off'.
                    For 0 you turn off the visibility of both. If they are shared you will get the right count of shelves.
                    but then you have to use adaptive components....
