3D car - DWG to Revit as site object?
    I found this car on RevitCity, it works pretty well for plans/elevs/sections in hidden line. Anyone know how they exported from a DWG and not get the triangulation (see attached image)?
    Also, it's odd that it came in as a Site Object. I'm still pretty new to Revit, but in my limited knowledge this seems like a good option; small size, true 3D and renders OK in hidden line. Are there any pitfalls I'm not catching?
    Thanks in advance.
    -tofu
    There's a workflow through Max to hide the edges. Most will tell you that imported files are bad in Revit. Do what you gotta do but be aware that it's a known issue.
    Greg McDowell Jr
    about.me/GMcDowellJr
      Dammit, prior to posting I searched the forum with several keywords; except never trying "triangulation". Figures I'd leave the most important word out. Proper search found it right away. Also, duly noted on the import warning. Thank you Greg.
      Here is the link incase it helps others.
      https://www.revitforum.org/blog-feed...into-revi.html
        Maybe a crazy question but using Sketchup files from -warehouse. Would that give the same or maybe better car objects? There a tons of great cars and furniture in skp format..
        https://knowledge.autodesk.com/suppo...4EDE0-htm.html
          same issues
          Greg McDowell Jr
            SKP to DWG, no problem here
            https://3dwarehouse.sketchup.com/mod...ba0a85525fb823
              The *problems* exist in Revit, using SKP, DWG, and other geometry that gets "flattened in" through SKP and DWG. It may look fine, but it will eventually cause the *dimensional wackiness* that imported geometry causes in Revit Files.
                This indeed needs to be dealed with 'within Revit'
                  Yep! The way you deal with it is not to use that garbage, unless you want your model to be all jacked up. That's the way it is, at the moment.
                    I use very generic car shaped families to give the impression that a vehicle is there. Basic sedans, trucks and minivans work best. By basic I mean it's little more than boxy extrusion with the edges rounded. Then I use a smoked glass material so it's little more then a suggestion of a vehicle. It's not a great solution but it's quick and does the job well enough to satisfy the city officials.
