family extruded forms
    Hi everybody!
    I have to create these "cubes" extruded from the facade.
    The walls have different lenght of extrusion from the facade. I have to work with families for an exam. I would like to create a instance parameter "lenght" this way I have only to change this lenght to obtain the different dimensions.
    From wich family I can start? Becouse I haven't find a family with walls and floors.
    Using masses is considered a creation of a family?
    Thanks everybody!
    It looks like a window family to me.
      heh, or curtain walls, or GMs, or floors/walls/roofs. Revit gives one a lot of options for construction like this. Use the one that you are most comfortable with, AND gives you the informational and documentation output that you need.
        Because there are blank sections in your walls and what looks like different height openings, curtain walls might work but (I'm talking grids here) could potentially be a PITA, same with floors walls roofs (too many sketches to update when things change). I'd be looking at window template too. As Dave says, start with what you know.
          thank you to all of you!
