Length/Width/Height in Schedule Creation of Bookcase Family
    I have created a bookcase family in Revit.
    Once importing the family into a Revit project (simple 1 story home) I create a sheet and import the furniture schedule onto the sheet.
    4 of my bookcases with different parameters are placed within the home.
    I wish to have the length width and heights of each instance of the bookcase found on the schedule located on my sheet.
    Is this a possibility? Thank you!
    Its possible. You will have to use SHARED PARAMETERS in the family, not Family Parameters. Once you get in to using SP's, scheduling will start to work.
    Oh, unless the L, W, and H are the OOTB parameters, which you can also schedule.
      sorry...i'm too curious
      what is OOTB?
      "-Bueno, pues ahora que los dos nos hemos visto el uno al otro -repuso el
      unicornio-si tu crees en mi, yo creeré en tí, ¿trato hecho?"
      Lewis Carroll
        what is OOTB?
        OOTB = Out of the box (native Revit content)
          what is OOTB?
          "Out of the Box" ... or in this case, since it's a family, parameters that are built into the family template.
            Mmm...
            Must be those parameters that are defined in the family template
            Lewis Carroll
              Mmm...
              The out of the box parameters mentioned here are actually system parameters defined in the Revit code. They are actually by the category and part type not specifically the family template.
              To understand more clearly create a new family from the generic model family template and go look at the parameters in the Family Types dialog. You will see only Identity Data parameters. Now change the category to Casework and Revit will add 5 new parameters.
                And can not be deleted
                Lewis Carroll
