Visibility parameters and formulas
    Hi there,
    Can someone help me with formulas in family types? I've got visibility parameters for three types of door swings: 90 degree, 120 degree and 180 degree.
    What I want is to be able to check one box and have the others automatically uncheck if they are checked. For example: 90 degree is checked, but I want to change it to 180.. I wanna click 180 and have 90 automatically switch off, and if I switch again to 120, to have 180 switch off...
    I can get one to switch off by using the "not(90 degree)" parameter, but I want something like "not(90 degree) not(180 degree)" but Revit doesn't like that.
    Any thoughts?
    TIA
    John
    TRY
    not(or(90 degree), or(120 degree)
    -Alex Cunningham
      Originally posted by Alex Cunningham View Post
      TRY
      Nope. "Incorrect number of arguments to function"
      Thanks for trying. I ended up just making them all stand-alone. I was just trying to prevent accidentally showing two types of swings the smart way. But the old fashioned way will work just as well.
      Anyone else is still free to take a stab at it. If you just like to solve problems
        not(or(180 degree,120 degree)) works for vis control of the 90 degree option, but using similar formula for the other options cretaes a circular reference..... hmm
        Randy_CaS
        Senior Member
        http://www.captiveaire.com/
        Commercial Kitchen Ventilation Systems
          Originally posted by Randy_CaS View Post
          not(and(or(180 degree,120 degree))) works for vis control of the 90 degree option, but using similar formula for the other options cretaes a circular reference..... hmm
          sorry i was in a rush out the door and didnt finish the )))
          I thinking the exact same thing the circular chain thing. Let me test something will report back in a few.
          -Alex Cunningham
            does this make more sence? Basicaly it you use "90 parameter" for your object assignment. the user will use "90 visibility" for their selection.
            This formula will only allow only one visibility to be on at one time. If the user selects more then 1 check box everything turns off.
            EDIT: simplified the formula for "90 parameter" "120 parameter" "180 parameter" my brain makes formulas in a strange way sometimes.
            EDIT EDIT:
            removed "90 formula" "120 formula" "180 formula" built it into 1 formula
            Alex Cunningham
            Last edited by Alex Cunningham; August 11, 2011, 09:54 PM. Reason: simplified formula, updated attachments
            -Alex Cunningham
              EDIT EDIT:
              I didn't 100% follow you in the parameter/visibility distinction. I noticed one was "data" and the other was "other".. mine are set up as simple yes/no graphic parameters.
              I wasn't able to open up your attached family cuz my company is still using 2011 .. think you can step it down? I could prolly figure it out from your example if I could open it... I know, we're way behind the times
              oh, and thanks a lot for the help guys.
                My file is in 2011...
                the formula is fairly simple.
                You cant name your parameter just "90" it cant be only numbers.
                It takes 2 sets of 3 visibility parameters to do what you want.
                For my example I use "90 Visibility" "120 Visibility" "180 Visibility" and "90 Parameter" "120 Parameter" "180 Parameter"
                The "Visibility" paramters are the user defined selections. This is what the user will use in the project to select what swing they want to show.
                The "Parameters" parameters are assigned to your family objects and have the formulas.
                and((not(120 Visibility)), and((not(180 Visibility)), and(90 Visibility)))
                and((not(120 visibility)), and((not(90 visibility)), and(180 visibility)))
                and((not(90 visibility)), and((not(180 visibility)), and(120 visibility)))
                This formula will also only allow only one visibility check box on at a time.
                Ive reposted the family for you.
                -Alex Cunningham
                  d'oh. I forgot this drb I'm workin on is using 2010.. lol whoops.
                  I'll give it another shot. Thanks!
                    2010 version for ya
                    Enjoy
                    -Alex Cunningham
