Tutorial please on nested detail component
    Here is the video:
    Time 4:00 , when he makes mark on "pantile" and detail component appears
    How did he do that? How he applies to fascia, and where this fascia should be applied?
    I really will give you rep for this, and it could be even Post of the month!
    bangobeat
    Senior Member
    I'm going to guess that the Profile for the roof fascia contains a nested Detail Component / array/ repeating Detail that has a Reference Line and angular dimension parameter
    setting and a visibility parameter so that when loaded into the project it can be adjusted to the roof pitch and turned on/off with the check boxes in the Fascia Properties box.????? Just a guess.........................
    cliff collins
    BIM there, done that
    Cliff B. Collins
    Registered Architect
    Autodesk Expert Elite
