custom tag which can be rotated
    is it possible, or is it a good idea?
    It is possible (door and window tags can already do this) but not for all categories (cause, weird enough: curtain panel tags cannot, see this thread).
    Try to check the "Rotate with component" option in the Tag Family
      thanks Martijn, seems "Rotate with component" doesn't work, in my case, lighting devices.
      don't understand why Autodesk cannot make it happen!
        Me neither, seems a bit of arbitrary (for instance the doors/windows vs Curtain Walls). Wishlist item I guess..
