Array issue
    Array issue
    I am going on two days of trying to figure out what is broken in my family. It is a casework family with some nested parts. I stripped everything out to get a small file, and to see if I still had the same issue (which I do)
    I am trying to create a parametric array per length. This is where I went and followed the instructions.
    Creating an array from the Course Revit Families Workshop
    It all works, but where I have issues is when I change the "Depth" in the family. Once I do that, the grouped parts act weird. They offset vertically 3/4" and I can't for the life of me figure out where the issue is.
    Can someone take a look at it and see if they can find what is going haywire? In my file, change the depth to 18" and you will see what I am referring to. Everything was locked to the reference planes before array.
    you need to align and lock the first and last element in your array to a common reference.
      Thank you. Worked perfectly. Not sure why I didn't think of aligning.
      I can't figure out why this wouldn't already be locked to the original reference plane. Dunno. Some things will just remain mysteries apparently.
