Multiple nested families
    Hi everyone,
    I created a host family, with (nested) family A1, A2 and A3 in it.
    The nested families can be switched by the "Generic Models" method (see attached example).
    And now i would like to add nested family B.
    Family B should contain parameter formula's witch are different if A1, A2 or A3 is active.
    Is it possible to let family B know witch family A is active.
    I ask this because i would like to have a minimun off formula's in the host family.
    Not in the way you are describing. Depending on what you're after... maybe. We've talked about this recently on RFo so you might search a little.
    You also might consider if nesting family B into A will get you what you need.
    Greg McDowell Jr
    about.me/GMcDowellJr
      Thanks GMcDowellJr,
      I have been searching, but i can't find it so far :crazy:. Do u remember some keywords/labels to search for.
      I have tried the nesting before, but this will result in other problems for me.
