Mass in a generic model family
    I created a generic model family to 'act' as a residential dwelling unit. I created a mass in this family. The family has formulas to create the shape of the family and parameters so I can track it (area, type, etc.) in a generic model schedule. When I place the family (its a generic model) in the project the mass shows up solid and does not act like a mass. Isn't filtered out via visibility/graphics when mass is turned off.
    Is a mass only a mass in a mass family???
    I know that I can add a parameter to what was the mass shape to control the visibility of this object in the generic model family but I just wonder if I'm missing something?
    I haven't used masses much...
    (using Revit Architecture 2013)
    Travis Vaughan, AIA, NCARB, LEED AP
    LinkedIn Profile | Twitter: @TravisUsesRevit
    Originally posted by tidalwave1 View Post
    I created a generic model family .... I created a mass in this family. ...
    How could you create a mass in the generic model family? "mass" is a category, and "generic model" is another category. Even if you make a "mass" family, and try to load it into a "generic model" family, Revit won't allow you to do that.
    Maybe you are calling "mass" to a simple extrusion? That is not a mass, but a solid. If you want a true mass that is flexible and can be used for pre-design, schedules, mass floors, perimeters, etc., there are two ways: a) in place mass, or b) new family with the mass.rfa template.
      Okay, that makes sense. I guess that I always equated extrusions with masses. Don't know why but...
        As Alfredo mentioned, I would suggest using the conceptual mass file (mass.rvt) as the base file to start from.
        C:/ProgramData/Autodesk/RAC 2013/Family Template/English
        If you are looking for inspiration, I suggest looking into Zach Kron's work.
        RB Cameron, AIA, LEED AP, EDAC, NCARB
        Architect - Parametric Designer - Visualization Instructor
        Download Healthcare Revit Models
        Download Revit+3dsMax Models
