Creating Truss
    Creating Truss
    Hi there!
    Anyone? ..
    I can't figure out what went wrong with the Truss Family I created. I have two questions..
    1. How to properly aligned my truss to the Roof Beam Level?
    In family interface, I believe the structure diagram is correctly placed/assembled. I also locked vertical web, bottom bar and top bar aligned to the reference plane . I attached here the diagram of truss family I created. But when I load it the my project, even though I selected the Roof Beam Level as my based level, the Truss structure still is not aligned to it. See attached screenshots.
    2. My truss connection seems unclosed/ not connected. It is really that like that? 'Cause I checked the analytical diagram, lines/stick seems connected to each other.. So i presumed its okay though.
    Thank a lot guys, Hope you can help me:-)
    Post the truss family.
    -Alex Cunningham
      You can change the truss Bearing in the properties palette. 2014-05-15_0944 - cellophane's library
      Not sure if that's the issue or not but it is worth a shot.
      chad
