swimming pool 6m x 12m
    Hi everybody, i looking for a swimming pool family and is possible "parametric"
    Do you have one for me ?
    Il vaut mieux un qui sait plutôt que dix qui cherchent
    I'm Just simple Architect en France !
    Is it a fiber glass pool?
    If not, I would use walls and floors.
    Gonçalo Feio
      whatever, i just need swimming pool.
      But i use floor and wall, how do you make water ?
        in place mass with water as material ;-)
        Julien
        P. DAC
          ok i test this answer immediatly.
          Do you use an small thickness ? 2mm ?
            I personally "fill" the pool with water leaving about 6 to 8 inches of space from top (15 - 20 cm)
            Juan Carlos Moreno
            Sisley Cosmetics
              Not a mass family, please.
              Masses are for mass, and it's visibility is usually off.
              Generic models are perfect candidates for the rectangular water.
              Gonçalo Feio
                You make the floor with the total thickness and leaving 20 cm to the over top level ? that's right ? Do you have a picture please ?
                  Here's an example:
                  (credit for the image: Armando Martinez / [email protected] )
                    I make an in-place family. typically i set the category to site and create an extrusion that fills the pool. I set the material to water for the extrusion. The "water" ends like I said about 20cm below the top of the pool (where the water would spill out). Sorry I have no pics right now.
                    Juan Carlos Moreno
                    Sisley Cosmetics
