Multiple Voids in family
    Hey building a crown molding for a kitchen and it needs to be a U shape and parametric ( i tried using a sweep first and it worked fine, but the problem is since i'm using a wood material, I cant control the direction of the grain. I need to create 3 parts and link in on a 45 where it joins, Ive used the void feature for the two outside piece, but when i join the middle piece and add the void, it also cuts the 2 other pieces, is there any way to tell the void to only cut the front piece and not the two sides
    thanks.
    agh nevermind, i created a extrusion shape, converted it to a void then cut it, thanks
      I've found that to be the best approach for voids in families. Much more control over what is cut and the constraints on the void. :thumbsup:
      chad
