Plss help asap room tag and roombook problem
    this is the last task for my family..ive done all of the required task except for this annoying room tag.i made some room tags for the project.the goal is to have different room tag families loaded in a project so if someone just wanted to change the room tag someone can just click the room tag and select on the dropdown box family instead of typing it on every different room and with its designated room number.the problem is that i have already made the rom tag fmailies however when i try to calculate the room with roombook.he schedule doesnt show the right name with its right room number.i used text for the room tag.not labels..because when i use label it just shows what is seen on the picture attached.can someone help me with this?it would be great..thanks!
    this is the attached image
      this is what happens if you use label for the room tag instead of text
        First Select room, give desire room name in identity data
        see image.
          but thats the one we would like to avoid.typing .i like to make it fast by making a different room tag families.already made them but however it doesnt show in the QTO/Roombook.ill post more pics for reference.
            some reference images.sorry for the erased parts because i actually type my native language..now i made it in english so that most people can understand what im saying.thank you very much!
              What u are going to achieving is not a good idea. U must enter room name one by one in schedule or if u intended only room tag tray space and space tags
                You realize that by using text instead of filling out the room data your screwing your consultants when they try to copy your rooms to spaces right?
                I've had over 600 rooms in one model, I never had any issues with room naming and numbering as I could just click the label and change the info. As for schedules I would just copy the room name and paste in the other fields as the pull down gets too long.
                Your missing out on other things that a room can do too if just trying to use text.
                  oh..but are there any quicker ways? because my boss wants a more efficient way,faster.or just typing manually is the best choice?
                    Sigh... keep trying you'll get it eventually.
                    Theres two pieces of information that you really need to fill in properly;
                    Room Number - Must be unique to identify a single room and if it gives some information about location (Like level number) thats also helpful.
                    Room Name - Must say what the room is and what its function is. I can see why you want to standardise this and have only a list of options but you have to put this in the room or it is useless.
                    For ANY OTHER parameter you want to add to rooms you can sort them by room name and change them for all rooms of the same type in one go, that is where revit saves time.
                    These two parameters are especially important for MEP guys because they are the only two we can import automatically without some extra add-ins and stuff.
