How to constrain visibility paramater
    Hello Everyone
    While working today a got a dout that if visibility paramater can be constrained, like if there are 2 visibility paramater,
    what i want is if visibility paramater 'a' is actived then visibility paramater 'b' should be active.
    Considering visibility paramater as instance paramater.
    Does any one have a solution for this
    Originally posted by amarkrish108 View Post
    Hello Everyone
    b=a
    Is there a reason you can't just constrain both elements to the same parameter?
      Likewise, many times you need to turn on thing off and something else on.
      If they are mutually exclusive, you need to use:
      c=not(a)
      I kind of wish you could use the "not" modifier directly in the Visibility. Could save a bunch of parameters
      Dave Plumb
      BWBR Architects; St Paul, MN
        There are a lot of options as you can see. This thread has a TON of information about formulas: http://www.revitforum.org/tutorials-...day-usage.html
        chad
