3D sweep path?
    3D sweep path?
    this should be simple and probably is but I'm struggling with making an offset rod door pull. I'm in a face based generic model template and I am only able to sketch a sweep path in one plane. As soon as I sketch the start of a path in one plane Revit won't let me sketch in any other plane. There's gotta be an easy way to do this.
    To the best of my knowledge this is still a software limitation. You can sweep all day long in 2 directions but a 3D sweep is something still on the wishlist.
    EDIT: I take that back Aaron mentioned a sweep along 3D model lines over here
    http://www.revitforum.org/showthread...D-DWG-to-Revit
    eric.piotrowicz
      The only way I know to create that shape is to create three unique sweeps and then join them.
      Sarah Foulkes
      Not a Revit Robot
        I know that it's possible in a family template environment because I have an offset rod pull rfa file that looks like my attachment and the pull is a sweep. There's a way to get there but I don't know how.
          Sure it´s possible - even with a single sweep.
          The trick is to create the path as model lines (create and name a few ref. planes, and use those as workplanes for the model lines) and use those model lines to "Pick Path" for the sweep.
          Have a look at this example, and reverse engineer from there
            Munk is right. Doing 3D sweeps in Revit almost always requires you to first make a 'jig' of model lines or from another solid of some kind, then using the Pick Path option to make the path.
            Jeffrey McGrew
            Architect & Founder
              Cool trick- I learn something new everyday.
              Sarah Foulkes
              Not a Revit Robot
                Oops, while I was doing my illustration, Munkholm beat me.
                Now all I have to say is "see illustration".
                  But Alf, your illustration is so much better - Nice :beer:
                    Thanks guys,
                    learned smth this day. this forum is really the place to be.
                    Julien
                    P. DAC
