View Title with multiple Extension Lines?
You cant do it with an instance parameter, either... Since you dont place instances of the view title, you place "Viewports" which use Types of View Titles.
The only way is to use the system extension line (1 line) or have a different View Title Type for each length of extension lines, and have different Viewport types.
Anyone know how to edit the extension line that extends from a view title and has grips on each end. I actually have to access the view port to extend...October 1, 2013, 07:04 PM
In lieu of using the default extension line in view titles, I drew a line in the view title family and used an instance parameter to control the length...
Channel: Structure - Family Creation
March 30, 2016, 08:10 PM -
One of my views has a REALLY long view title. I need to show it on two lines. I attempted to do as the following link suggested and add a line feed...October 22, 2015, 07:19 PM
Hey Community;
im sure this question has been raised; but i was trying to make a custom view title for a project template. basically trying...-
April 16, 2019, 09:08 PM -
Is it possible to adjust the view title line so it doesn't extend the length of the view itself by default? I would rather lengthen as needed rather...January 22, 2012, 05:29 PM
Monumetric Footer In-screen
