Down Pipe Creation
    Down Pipe Creation
    Has anyone done it? Has it worked correctly?
    Im trying to create a parameter based downpipe, rather than individual DP files
    The goal is to have it so i can adjust the width of the eave, the pitch of the roof, and the DP will automatically change to the correct position, included the angle of the turn of the down pipe.
    my issue is i cant seem to define the interesction where the angle of the turn meets the eave width. i always use rerference lince and set everything up from that but im struggling to even get that to work in this instance!
    Has anyone done this or attempted it before? Is it a lost cause?
    Scott_CJDH
    Revit 2012: you can now use Adaptive Components in the project environment.
    Hoping this will could be a good solution for downspouts.
      Scott.
      Here´s a couple of examples that you can have a look at - Notice that most of the parametric dimensions is instance based, so they can be dragged and locked to fit the model :beer:
      And like Jonas suggested, AC´s could also be an interesting solution in Revit 2012
        Perhaps something like this?
        Use: draw downspout using 5 points. Switch types for round versus square. Use radius parameter on an instance basis for sizing.
          Very nice! Welcome to RFO :beer:
            Thanks you very much!!
            That's very helpful! Even for 2015, revit still has no down pipes (spouts) in the library, which is a pretty fundamental component in an architectural drafting program.
              Thanks Binrock. very helpful.
                Thanks Munkholm + Binrock for sharing your creations.
                Another Revit user wishing plumbing could deal with real world products that arn't all round (rectangular/square downpipes)
                • Pipe Fittings
                  I am modelling some pipework on a project and the main corridor has a slight change in angle (approx 2°). This is causing a problem for my pipe run as...
                  October 20, 2011, 09:59 AM
                • Builders Work Holes!
                  Hi all.
                  Is there anyway of producing a drawing, from a co-ordinated MEP layout to show builders holes through walls that show height and...
                  October 20, 2015, 09:06 PM
                • Pipe Fitting angle precision on the fly?
                  I've been racking my brain for an hour and still can't get this one figured out. I've managed to narrow my issue down and now I'm stuck. The issue is...
                  November 5, 2012, 05:11 PM
                • How to Keep Sloped Pipe Accurate?
                  Is there a way to keep sloped pipe accurate? Sometimes when I move fittings or pipe around the entire system shifts around a bit. I think this is because...
                  November 5, 2015, 06:54 PM
                • Pipe Markers (Colored Sticky Wrap with Text)
                  So, got a question for you all.
                  I've been asked to make some pipe marker families. As I am not an MEP guy, I have no clue as to how these...
                  November 9, 2012, 10:19 PM
