Creating custom green roof with Hills
you should look at Nucleus Project, now part of Vasari project2.1 here.
Create the main mass and the colliders, play with Nucleus, then floor by face. It should work.Julien
P. DAC
Sure you're right. It was just my first thought seeing that roof; looks as it was covering big balloons....
I play often with Vasari so that leads me to.... my previous answer.
It's more funny.Julien
P. DAC
I would suggest a Mass, fairly easy to do... create the domes using a revolve on a extrusion base plate. Join together and apply Roof by Face.Martijn de Riet
Good day hammadc
you could also design the undulating shapes with your massing tools by placing some 3d points on a plane. Draw a spline through 3d points and than while having all the lines selected creat your form. this will allow for you to manipulate the 3d points later on in x-ray mode and give you a more intuitive interaction with your shape for the roof.
When you are done and happy with your result, follow the steps above and go roof by face.
Hey guys good to see you all again.
I resigned from BIM manager position and now I am playing my own boss. hope you are all well,
Cheers.MW
Cheers.Klaus Munkholm
anyone knows how to do this roof type where the roof extends to become the wall in revit architecture? i was able to represent it in sketchup...January 8, 2011, 11:57 AM -
Hi all,
I'm fairly new to conceptual mass modelling, but I've created a half-shell type form that curves over my building, like a giant canopy....September 17, 2015, 06:40 AM -
I created a very simple mass from 3 arcs. And could not make roof. Anyone explain this ?
Simple Mass
...November 26, 2014, 05:48 AM -
Hi, i need help urgently with this roof profile. I need to create a roof that sweeps upwards, and is in a curve roof profile. Is there a way i can do...December 30, 2011, 11:37 AM
I am struggling with the best method on how to create this roof. Its quite interesting....May 23, 2014, 05:55 PM
Monumetric Footer In-screen
