Toggling Equality makes model overly constrained!
    Hello ... I have cube in in the conceptual modeling environment. I want to center this cube on about central workplace.
    I am use the dimension to in force equality, but I always get the alert: "the model would be overly constrained"!!
    How do I get around this limitation?
    Thanks,
    Use Reference Planes to lock the dimensions to, not the model / mass geometry.
    Cliff B. Collins
    Registered Architect
    Autodesk Expert Elite
      Yup, draw your geometry in refplanes. Constrain those and then lock the CM faces to the refplanes.
