Slicing mass, can you do it?
    I'd like to create a mass and then slice it longitudinally.
    I'll have a trench that will follow a top surface. I was gonna create ref planes in certain intervals and then place mass profiles and create a form. Then i'd like to slice that mass. I though i was gonna be able to do it with "Divide surface" option, but i can't seem to be able to.
    There are gonna be like 50 ref. planes, trench moving in all 3 axis. The problem is i'd like to have 3 masses running alongside like this, so instead of doing 3 different masses, i'd do one and then slice it. Is this possible?
    How would you go about it if it isn't?
    Kind regards
    MEP CAD / BIM technician - @MatevzPetric, LinkedIN
    Trying to learn something new every day
    create levels in elevation or section. use "floors at levels" command. it will more or less create a line through the mass where you want, and you can create floors at those lines. Slicing..not so much though.
      Argh, i just tried it. if this is what you want, it would be relatively easy:
        Thanks, but that doesn't seem practical in my case. I managed to do it relatively efficiently.
        I created a profile and i just place it on Spline point workplanes along, then blend. It's still work, but i think i can manage to get the end result.
          Appreciate the effort! But it's a complicated form. I think my approach is not so bad in the end. i think i'll be able to make it work.
