Revit Rendering
    Revit Rendering
    We've been using revit to make quick renderings of projects which works fine. We now need a high resolution rendering to be used on a construction site sign. To make one that size takes days for Revit to render. Is there a way to get a high resolution rendering from Revit any faster, or do we need to use a different rendering software?
    First I would check with the sign company and see what they need. Those large scale signs are frequently fairly low-res (72-150dpi) since they are viewed from a distance and often while in the car on the move. Once you know what you need, then I'd figure out how to approach the rendering.
    chad
      You might have luck with Enscape - I've used it on the occasional project where we have some rendering requirements. It works with Revit really nicely and doesn't have a huge learning curve, and I think you can do up to 4k renderings.
