Adaptive Fence - How to get post to rotate with fence direction
    I am trying to create a simple birdsmouth fence family using adaptive points. I'm going to snap this to a divided line in the project, and use the repeat tool to generate all the panels. I've nearly got it working, but can't seem to get the fence post to rotate to line up with the panel direction. Tried adding an angle parameter constraint but it seems to break as soon as I move the second adaptive point.
    Any ideas? Family attached in case anyone gets a chance to play around with it.
    Cheers
    use GM to create post profile, then nested into AC, use point instead of ref line to rotate that nested family
