Parametrically rotated element-Mass environment
    Hi there ALL
    Could you tell me please how to rotate element (extrusion or similar) using parameter for its angle?
    Square box extrusion rotating with respect to its centre point. I tried to do it using reference plans but as a consequence rotating reference plan was deforming the box :banghead:.
    Any hint, link please and thanks
    The moment you want to parameterize angles you need to use Reference Lines, not reference planes.
    A more elegant way is to place a ref line and make the RL the work plane yoy put the extrusion on. Many less constraints that way.
      Thanks a lot for your answer it was very handy
      I have found this tutorial:
      https://www.youtube.com/watch?v=3IWum86W-zo
