Adaptive family - points based
    Dear All,
    I tried to make an adaptive family for roof covering. The profile contains two ribs on its two side and between a sheet. The family have to follow a double curved surface, so I applied 3x2 or 4x2 or 5x2...etc points to create it.
    I want that the angle between the ribs and the sheet always be fixed (don't lie down for example). Actualy if I put the family to a double curved surface it isn't work as you can see the attached picture.
    I tried different solutions to fix the ribs but the problem always the same or overconstrained the element.
    Does anyone have some idea to fix it?
    I attached the profile in dwg format and printscreens of the actualy problems.
    Thanks!
