Gradient glass
    Gradient glass
    I am trying to get a Gradient glass from Opaque to transparent in both rendering and elevation.
    have Any idea?
    You could try making a gradient map file (.png or .jpeg ) in Photoshop with the colors and percentage of gradient you need,
    then use it as a custom map in the glass material's render appearance. Take a glass material, duplicate it, and apply your custom map.
    Renderings will then show the gradient glass. For elevations, try using a Realistic View with a 3D View oriented straight-on (front, side, etc. of View Cube.)
    Cliff B. Collins
    Registered Architect
    Autodesk Expert Elite
      In your material editor, under the appearance tab, you can select gradient in lieu of an image file.
      chad
        Has anyone figured this one out? I've tried and my image come out a patchy grey when I use a PNG file. When I try gradient, I don't see any option for making part of the gradient transparent - just two colors.
          You can apply a gradient as a transparency that sounds like it will work, but I haven't tested it at all.
          Julie Kidder
          Architect + BIM Director
            I did some time ago. As I remember I used photoshop to create a material with an alpha channel and it worked. You have to put the gradient mask into the cutout of the material, thus you have to start from a material that holds cut out.
            If I watch...I dream, if I listen...I think, if I do ...I learn.
            blog
