Tool icons disappeared
    Once in a while, My tool Icons diappears sometimes.
    I can simply fix it by Restarting the software but what is causing it?
    Try scrolling through the ribbon settings. Also try unchecking then re-checking all items under the UI tab.
    see attached.
    Cliff B. Collins
    Registered Architect
    Autodesk Expert Elite
      I hate that icon!
      The only reason I've ever seen anyone use it is to restore their Ribbon after they accidentally clicked on it (and didn't know that they did)
      That setting belongs in Options, not somewhere that's too easy to accidentally change.
      I assume there are a few people that actually use something other than the full Ribbon (although I've never met one)
      Even assuming that, does anyone bounce around between the different configurations frequently?
      I'd guess 99% of people only use full Ribbon, and 99% of the people who don't set it to one style and leave it there.
      Which would leave 0.01% of people who intentionally click on the icon more than once a day.
      By my totally accurate assessment.
      Dave Plumb
      BWBR Architects; St Paul, MN
