text
    text
    need your ideas and tips to make a text note have really a white , and not only where the text is (see picture).
    thanks.
    Julien
    P. DAC
    Masking region behind the text?
    Chad Koscinski | Architect
      Yep, but not on sheets.... Only title blocks will achieve this I guess.
      thanks for your answer.
      Julien
      P. DAC
        You could create a drafting view that has the text and masking region behind. Then drag that view to where you want it on the sheet (make sure it has no view title). Kind of a clumsy workaround...
          I would set the text to opaque rather than transparent in the text properties. This should give the result you are after.
          Ian Kidston
          http://allextensions.com.au
            Humm, If you look at the picture, the text has white , but not until the border.It is set to opaque in fact. Only the letters are concerned, I would prefer the entire area within borders.
            Julien
            P. DAC
              Sorry, misunderstood what you are after, (message to self - don't read so quickly!) and yep as others have noted it is going to be a bit of a kludge work around.
              Ian Kidston
                You can do a masking region on a sheet. Not sure how it will work on text though.
                Dan
                  Use a Generic Annotation.
                  You can place a hardcoded text if it's something you will need to re-use every time.
                  You can also create a instance text parameter if you want to be able to retyp the text as needed.
                  use a filled region with invisible lines and white filling as a and you're good to go. Do NOT use a masking region, this won't work.
                    You can't place a Generic anno in a 3D view though, looks like the image in the OP is a 3D view
                    Revit BLOGGAGE
                    http://www.revic.org.au
