This is a little tip that was developed with the assistance of AutoDesk at my old firm and helps to control file size, view generation time, and other similar things.
When creating a family go in to each elevation and the plan view and draw masking regions and use symbolic lines where you feel you need them to project the model in plan and the elevations. Then select the model and change the visibility so it only shows up in 3D and Fine Detail. (Note** be sure to lock the symbolic lines and the masking region)
This is extremely helpful with RAC, but could prove just as useful in RST and RMEP.
