Model In-place - assign to subcategory
    I am trying to find a way to assign a model In-place element to a subcategory to help with visiblility control, but have not found a way to do this. Is this possible? Thanks for your help
    When you start the in-place element you should get a popup asking about which subcategory you want to use. If it's already made, edit the element and at the top of the home tab you will see an icon with a yellow folder (same as in the family editor) that will let you set the category.
    the better solution is to create a family and load it into your project. If there is any chance at all that you will use it again a family is a much better way to go.
    chad
      Thank you for your reply, but I still cannot see away to assign it to a sub-category. Only the main category is an option. I am attaching screen shots of the "family category and Parameter" and the "object styles" dialog box. I must be missing something.
        First, you'll need to create the new sub category (if it doesn't exist already).
        Edit the in place family like Chad suggested. Then, hit the Manage tab in the ribbon. There, on the left, you will see Object Styles. Open that.
        Now, you will see all the categories in the model. On the bottom right, you'll see Modify Subcategories. Hit New. Another box will open. Name the sub category, and make it a subcategory of the proper category. Hit okay a few times. You now have a sub category made.
        Now, simply select the in place family (you must still be in edit mode) and, in the properties, under Identity Data, you'll see a subcategory drop down. Your new subcategory should be in the list.
        Dan
          misread it - sorry :hide: Dan's got it covered.
          chad
            Thanks Dan - just needed to find where to make the change....
              You can actually assign seperate pieces of geometry in the in-place faimly to differnt subcategories if you need that level of control.
              Jeff Hanson
              Sr. Subject Matter Expert
                Just FYI, you don't need to be in edit mode (for the inplace family) to create a subcategory. I just told you that way because you had to edit the family to apply the subcategory anyway. You can add the subcategories from the project environment the same way.
                Dan
                  I don't understand what you mean by you can assign subcategories from the project environment? Do mind elaborating? Thanks
                    Yeah, that was confusing now that I reread it. :hide:
                    What I meant was, in my first post I had you create the subcategories AFTER you started editing the in place family. You don't really need to do that. You can add a subcategory through the object styles any time. Whether you are editing the family or not.
                    Of course, you'll then need to edit the in place family to apply the new subcategory.
                    Dan
